Unconfigures IPFIX on a port or group of ports.
| port_list |
                 Specifies the ports.  |
N/A.
Use this command to unconfigure IPFIX on a port or group of ports. This restores the configuration to the defaults for those ports. The global enable/disable of IPFIX is not affected by this command.
The following command unconfigures IPFIX on port 2:
unconfigure ip-fix ports 2
This command was first available in ExtremeXOS 12.5.
